- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Daisy-chained RBS750 always goes to "poor" backhaul status if "Connected Orbi" briefly loses power
- Mark as New
- Bookmark
- Subscribe
- Permalink
I could not find my model in the dropdown selector. I have a RBR750 (let's call this R) with 4x satellites (RBS750) (let's call them A, B, C, D). Satellites A, B, and C connect directly to R. But D connects to A (i.e. daisy chain).
Somewhat regularly, A will lose power for 10 seconds. It reboots and gets back in working order very quickly. But D ends up with a purple status light, and when I check the "Attached Devices" page in my browser network monitoring UI, I see that D has a "poor" backhaul status (usually it is still connected through A, but occasionally it connects to R directly, at this point). It will stay in this poor status for days on end. It is not smart enough to try to fix the situation on its own. As far as I can tell, there is nothing I can do in the software UI to fix the situation. But if I simply power cycle A at the device, the problem gets instantly resolved after reboot.
Is this working as intended? It seems ridiculous that the system is aware that device has an issue yet makes zero attempts to fix it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Daisy-chained RBS750 always goes to "poor" backhaul status if "Connected Orbi&quo
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I've copied my question to that other forum you mentioned. Sorry for the misplacement.
Regarding distance between devices, clearly all my devices are placed in an acceptable range since everything functions fine if they all power on at the same time. The issue is that one device briefly losing power can bork part of the network semi-permanently, and the system is aware of that issue but does not attempt to fix it. I don't think changing distances would do anything about that (nor can I change distances).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please post distanced between the current setup in the other forum.
Thanks.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
