- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Dead RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dead RBR50
Good morning. I woke up this morning and my rbr50 was dead. Assume power surge or something. I need to replace. I currently have 3 satelites around the house 2 RBS50 and 1 RBS50 v2. I would like to replace the router without replacing the satelites. What routers are compatible with the system? Do I have to find a RBR50 or can i use an RBK50....
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Dead RBR50
The RBK50 is a kit containing both an RBR50 router and an RBS50 satellite. I do not believe you can purchase an RBR50 alone unless it is a used one. If you have had the system for less than 1 year, then contact Netgear for an RMA replacement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Dead RBR50
Does the back LED or top ring LED turn ON at all? Possible power supply is bad...
@JohnKuz wrote:Good morning. I woke up this morning and my rbr50 was dead. Assume power surge or something. I need to replace. I currently have 3 satelites around the house 2 RBS50 and 1 RBS50 v2. I would like to replace the router without replacing the satelites. What routers are compatible with the system? Do I have to find a RBR50 or can i use an RBK50....
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
