× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Disconnecting Satellite log availability?
jimmycrank
I have an orbi router, 2 rbs50 satellites, and a rbw30 satellite in AP mode.   I have had the system for 2 years and just recently added the rbw30 about 2 months ago to extend to the garage.   Things seemed to be working no issues for the last couple months but just started seeing one of the main satellites frequently disconnect.  I can’t tell if it’s going bad or how often it disconnects or it’s just a UI bug.   Is there a log that I can check to see how often it’s disconnecting?
Message 1 of 3
CrimpOn
Guru
Re: Disconnecting Satellite log availability?
There is a log file, on the web interface at the Advanced Tab->Administration->Logs.  I do not know if satellite connection/disconnection is logged (I have never seen either).  I set my Orbi up to email me the log file every time it fills up and I accumulate them into one big file.
I definitely see where the satellite renews the IP address via DHCP once a day.
There is also a "debug" log file that can be created on the "debug" page http://<orbi IP address>/debug.htm
I have not played around much with that, and do not remember ever seeing anything about satellite connections.
Message 2 of 3
Guru
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 914 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
