Orbi WiFi 7 RBE973
Reply
Disney Circle Passcode
shark1979
Re: Disney Circle Passcode
I am having the same problem. My passcode doesn’t work. Even when I enter the admin passcode that gets texted to me, it still does not work.
Message 26 of 42
Blanca_O
NETGEAR Moderator
Hi @shark1979
Please PM me the device serial number and email address.
Blanca
Community Team
Message 27 of 42
BGrind
I'm having the same issue. I've never used Circle but, would like to set it now.
@rao24 wrote:
I'm unable to login to meetcircle passcode.  I'm the admin but it keeps asking for a passcode.  I dont have it and tried with 'send code' option but never received any SMS.
How to get rid of this problem ? please suggest
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 28 of 42
Have you tried this issue in the section given over to Circle?
Circle Smart Parental Controls - NETGEAR Communities
Message 29 of 42
deengear
Tutor
I have the same problem. No SMS message ever reaches me. Then how can I enter the passcode ? I don't have the Circle brick device - just my netgear router R6400v2 and the app does say it is compatible. So why no text message ? I tried the 'resend' multiple times.
Model: R6400|AC1750 Smart WiFi Router
Message 30 of 42
Guru
Please post about this in the Circle app forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
https://www.netgear.com/support/product/circle.aspx
Message 31 of 42
deengear
Tutor
Posted to the link you gave.
Message 32 of 42
Guru
Good Luck.
Message 33 of 42
VerneArase
Apprentice
Same deal.
I've activated Disney Circle and now it wants a passcode. I don't remember setting one up, and the one I normally use doesn't work. And now it's blocking me due to the fact that my iMac is on 24x7.
Administration of these add-on services is way tougher than it needs to be.
-- Thanks, Verne
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 34 of 42
DexterJB
NETGEAR Moderator
Hi @VerneArase, I have sent you a message. Please check your inbox.
Dexter
Message 35 of 42
annipuc
I am having the same problem. It won’t send me a passcode.
Message 36 of 42
EftyM
I have to say this is really poor from Netgear. I gave up trying to sort it out. If anyone has successfully managed to resolve this please let me know . If Netgear monitor this conversation please note the process is seriously flawed and as a customer I expected much more support than a link to a user forum.
Message 37 of 42
Guru
Please post in the Circle forum for this product:
Good Luck.
Message 38 of 42
Guru
Good Luck.
Message 39 of 42
AndrewMac
Re: Disney Circle Passcode -
I am not receiving my passcode and so I cant access the app on my phone.  Please can you email me the passcode?  many thanks
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 40 of 42
Burying this on the end of a long running saga started by someone else is a good way of being ignored.
You would do better to start your own fresh question in the right place:
That will have a batter chance of reaching the Netgear people who run these things.
Message 41 of 42
AndrewMac
thanks
Message 42 of 42
Top Contributors
Discussion stats
Announcements
Orbi WiFi 7
