Orbi WiFi 7 RBE973
Reply
Display name of Device connected to Orbi Satellite RBS50 is UNKNOWN & Link Rate : N/A
tanveeris
Tutor
I have 1 Router RBR50 connected to 3 Satellite RBS50 with Firmware version V2.3.5.34 on router and all Satellite.
Recently after updating the firmware to V2.7.2.104 I was observed 2 major issues.
  1. Devices connected to router has proper Device Name while connected to the router, However the same device if it connected to Satellite the Display Name appears UNKNOWN.
  2. From the Orbi App > Device Manager > when I click Device connected to Satellite. In the device details Connection Type, IP Address, MAC Address , Link Rate. The link rate display as N/A and when the same device is connected to router the link rate is proper based on the 2.4 or 5 GgHz. Connection status.
After all attempt, Factory reset, Hard Reset with paper clip and what not, I restored the firmware back to V2.3.5.34 and everything found to be working as before.
It will be good to conclude Orbi New Firmware V2.7.2.104 has a bug? Anyone observed or facing similar issue?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 11
Accepted Solutions
Guru
Re: Display name of Device connected to Orbi Satellite RBS50 is UNKNOWN & Link Rate : N/A
Good to hear.
Please mark your thread as solved so others will know.
Enjoy. Smiley Wink
Message 11 of 11
All Replies
Guru
Message 2 of 11
CrimpOn
Guru
Yes. Same issue. Annoying.  Poor quality control.
Message 3 of 11
Guru
Something to let NG support know about for sure. I see this as well.
@Blanca_O
Message 4 of 11
tanveeris
Tutor
Yes, very much.
I am struggling with this for long now. So i did factory reset before and after upgrade too for router and all 3 satellites.
Message 5 of 11
Guru
Something to contact NG support about. They need to address this issue. Seems to be on going for a while now.
Message 6 of 11
tanveeris
Tutor
Hope someone from NG Support would pick this issue whenever they come across this post.
Today all over again i did factory reset still no luck.
@OrbiSupport
@netgearSupport
Message 7 of 11
tanveeris
Tutor
Hi,
it only works with Firmware verison 2.3.5.30 or 2.3.5.34, any version after this seems to have an issue. I have logged the call with NG Support and provided them with all details, proof, screen shot and everthing they request till now. I hope and pray NG Team fix this soon in near future firmware release 🙂
Download Link:.
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V2.3.5.30.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.3.5.30.zip
Tanveer
Message 8 of 11
Guru
Thanks for letting us know. Keep in touch with NG support.
Good Luck.
Message 9 of 11
tanveeris
Tutor
Dear Friends,
We have Good News and we should appriciate Netgear Product support team considered the issue rasied and helped to resolve the Link Rate status for device connected over Satellite with the latest  prodcution fimware release Version 2.7.3.22
I am happy with the new version so far and provide also my feedback to support team.
Only one last thing which i have observed is, if you connect the satellte over web interface (IP Address) the device name appears " UnKnown" however in the mobile app the device name appears coorectly.
Hope the team will resolve this in the next upcoming releases.
Update your router and Satellite firmware and share your view if any. Till then Bye and stay Safe 🙂
Tanveer
Message 10 of 11
Guru
Good to hear.
Enjoy. Smiley Wink
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3113 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
