- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Does Orbi RBR50 speed up the internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can the Orbi RBR50 Router & sattelite speed up internet ? and can you also use Netgear AC2200 tri band extender inbetween the Orbi router & satellite to extend signal to an outside location ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Does Orbi RBR50 speed up the internet
Orbi only works as fast as your ISP speeds are provided and can only work as well as your connected devices.
No you can not. You'd need another RBS if you want to Daisy Chain them to help extend wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Annomol1 wrote:Can you also use Netgear AC2200 tri band extender inbetween the Orbi router & satellite to extend signal to an outside location ?
The Orbi "backhaul" connection between router and satellite can only be (a) a direct WiFi link between them, which is limited by how far they can be placed apart and still get a "good" signal (Blue Ring Light), or (b) an ethernet connection. The ethernet connection can be either (1) an actual ethernet cable, or (2) something that "looks and acts like" an ethernet cable, such as a pair of PowerLine adapters, a pair of WiFi "bridge" products, a pair of coax MoCHA adapters, etc.
There is no WiFi product that can be used to connect two Orbi devices over their own WiFi radios.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Perhaps if you describe the situation, people can offer suggestions. i.e. There is an existing Orbi network and the goal is to .....?
For example, WiFi radios "radiate" omnidirectionally. So, an Orbi placed on the outside wall of a house, will project a signal "outside". That's how my patios get WiFi from my Orbi. 100 ft away? No way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an existing Orbi router & sattelite set up but want to use an extender after the satellite to extend the signal to an outdoor room in my backyard.
Is this possible ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sonething you can try to see if it will connect. Some extenders may not connect or be compatible.
@Annomol1 wrote:I have an existing Orbi router & sattelite set up but want to use an extender after the satellite to extend the signal to an outdoor room in my backyard.
Is this possible ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
