Orbi WiFi 7 RBE973
Reply
EX73000 Wall Plug Compatible with Orbi?
terrspin11
Follower
I am looking to connect a few a/v items via a Bridge to my Orbi system.  Will the Netgear EX7300 work in that environment?  I am assuming yes.
I had a old Nighthawk router set to Bridge, but the connection was solid for a month, then stopped working (i think the router had issues regardless).  I tried a Linksys re6500, but the connection is spotty.
So, just want to make sure the ex7300 would work.  Thank you!
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: EX73000 Wall Plug Compatible with Orbi?
Possible. It would be best to get another RBS satellite to use with the Orbi for best compatibility and operation...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 656 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
