jterp5
Jun 01, 2020Follower
Ethernet/wired connection(s) when using Orbi RBK50 on Verizon FIOS network
I'm considering installing an Orbi system (RBK50) with my existing Verizon FIOS gigabit service (I have a Quantum Gateway G1100 router provided directly through Verizon). I've found the following instructions for integrating the Orbi with the Verizon Fios service and setting the Orbi as an access point (AP): https://kb.netgear.com/000059619/How-do-I-set-up-the-Orbi-system-that-I-purchased-directly-from-Verizon-to-work-with-Fios
My wireless devices would be connected to the Orbi. My question is for wired devices, is it better/preferable to directlyconnect them to to the Verizon Quantum Gateway G1100, or connect them to the Orbi unit(s)? Does it matter?
Thanks in advance for any advice you can provide
If the Orbi is in Access Point (AP) mode, wired devices can be connected to either (or both).
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
jterp5 wrote:I'm considering installing an Orbi system (RBK50) with my existing Verizon FIOS gigabit service (I have a Quantum Gateway G1100 router provided directly through Verizon). I've found the following instructions for integrating the Orbi with the Verizon Fios service and setting the Orbi as an access point (AP): https://kb.netgear.com/000059619/How-do-I-set-up-the-Orbi-system-that-I-purchased-directly-from-Verizon-to-work-with-Fios
