- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Every 2-3 days I lose 90% of my speed on devices connected to the satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've had the the RBR50 for a little over a month. Every 2-3 days, I lose 90% of my speed on any device connected to the satellite. Making any change that reboots the network will speed things up again for a couple days, then it slows back down. I've connected a computer to the satellite via ethernet when this issue is happening and I get full speed, so it shouldn't be a communication issue between the satellite and the main. Netgear had me change the 2.4 and 5ghz channels, enable MU-MIMO, and enable Fast Roaming. It's only been a a couple hours, and so far, it kind of works? Now any device connected to the satellite is getting 100 Mbps less than the devices connected to the main, which isn't terrible, but....this doesn't make sense to me. Why would changing ANY setting be the solution if everything works at full speed for 1-2 days at a time? Anyone else seen this/have a solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Every 2-3 days I lose 90% of my speed on devices connected to the satellite
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Ensure Beamforming in enabled.
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275...
- Mark as New
- Bookmark
- Subscribe
- Permalink
What wired devices do you have connected to Orbi? Any mesh speakers (e.g. Sonos)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll try to answer everyone's question at once.
My Orbi is connected to an Arris SURFboard SB6183.
The Orbi is running firmware V2.2.1.210.
I'm using 2.4 ch. 6 and 5.0 ch. 44. These were both previously set to auto, but the issue persists.
There are a ton of networks around me; I'm in a condo.
The main and satellite are probably 40 feet apart.
Again, the part that doen't make any sense is that, via ethernet, I can connect to the satellite at full speed...so I don't see how it could be any of the wireless settings. If my devices connect to the main wirelessly, they work fine.
I've made the changes you suggested, so we'll see how it goes...but I don't think it's going to work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That might be a stretch in a noisy wifi environment.
Is the satellite at the far extreme of the property, or somewhere in the middle, between the extremities and the main router? The latter is better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might try setting the power output levels on the Orbi from 100% to 50% and see if this changes anything. Being in a noise or wifi congested environment can cause problems like this.
You might try turning OFF the Satellite for a short period of time and just test the router alone to see if the problem continues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It took ten days, but the issue is back. If I connect via ethernet to the satellite, I get full speed. So...I don't think it an issue with the main communicating with the satellite. Otherwise ethernet wouudn't work at full speed. This seems like a firmware issue or something.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you try setting the power output levels on the Orbi from 100% to 50% and see if this changes anything. Being in a noisey or wifi congested environment can cause problems like this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I disconnected my satellite since Netgear said there's a hardware issue and the main started doing the same thing. This is getting really frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you characterize the environement which you live? Is it a dense electromagnetic environment? (Lots of people, lots of WIFI SSIDs, near an airport? Near something that would produce a lot of radio frequency power?)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you try setting the power output levels on the Orbi from 100% to 50% and see if this changes anything. Being in a noisey or wifi congested environment as you already mentioned, can cause problems like this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since you said you had tons of wifi neighbors around, Being in a noisey or wifi congested environment as you already mentioned, can cause problems like this. After a reboot, the system works for a while, however due to the noisy environment, the system operation degrades. To help isolate your wifi from others, lowering the power output of the wifi radios can help in reducing the overall foot print of the wifi broadcast and make the foot print smaller. This does not redude speeds. It reduces wifi covrage and range.
I rebooted the main and it’s back to normal, for now. I’m grateful for the advice, but can you explain it a little? Like what does the transmit power have to do with losing 90% of my speed? And if a setting is an issue, why would power cycling fix it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wifi congestion can be problematic if you live near many others with Wifi signals. Reason why you can lower the power. If it's working at 50%, try 75% to see if you notice any drops.
I cut transmit power to 50% and so far so good. I lost about 50mbps, but haven’t seen any major drops yet. I’m not sure I love that I have to worry about any kind of degradation on a system I just bought two months ago, but we’ll see.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I get the same exact issue. I can go days at full speed wifi then all of a sudden it drops to under 10Mbps. I have the RBR40 with v2.3.0.28. I seems like a memory leak of some sort. once I reset the router it's back to normal for awhile. is the nvram overloaded? I've tried turing off and on daisy-chain beamforming mu-mmo and fast roaming always does it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
Has a factory reset and setup from scratch been performed this the update?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the size of your home? Sq Ft? 1100 sq feet
What is the distance between the router and satellite(s)? Around 30 feet, says good connection on the satellite.
What channels are you using? I’ve tried auto, 1-11
Any Wifi Neighbors nearby? I’d say around 6-8 wifi around me.
What WPA security modes are you using? WPA2-PSK
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings. I’ve tried on and off, and factory reset.
I’ve used other routers and custom firmware etc , and never experienced anything like this. I think it’s a memory issue in the router. I also see other people having the same problem. Why would ethernet get full speed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possible wifi interferences from neighboring wifi could be an issue.
Try this, turn OFF the satellite. Just run the RBR alone for a few days.
Set the power output of the RBR from 100% to 75% or 50% if you feel like it. Test this configuration for a few days. Test speeds wired and wireless right after making changes, then speed test in a couple of days.
Might try a manual FW re-load of the system, reset and setup from scratch as a last resort.
What device do you have connected to the Orbi system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how its going.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
