× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
ExpressVPn & Orbi
Tenoates
Tutor
ExpressVPn & Orbi
I have an ExpressVPN subscription but when I was about to install the VPN config on the Orbi Router, I realized that ExpressVPN does not have a specific one for Orbi.
I contacted them and they only have support for :
Would anyone know if these would work on the Orbi? TIA
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 3
CrimpOn
Guru
Re: ExpressVPn & Orbi
Orbi does not support any VPN "client" (which provides a tunnel to the internet for every device on the local LAN).  Orbi only supports OpenVPN "host" capability, which allows you to connect to the local LAN remotely (when you are away).
Any VPN software can be installed on individual devices on the LAN and the Orbi will not interfere with it.
If you look in the "fine print", it may turn out that some of the routers on that list are supported by installing custom firmware (i.e. not using the vendor firmware).
This is not what you wanted to hear.  Sorry.
Message 2 of 3
Tenoates
Tutor
Thanks for the reply. I used to be able to install a VPN in my asus router and I was hoping to do the same with the Orbi
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 19615 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
