- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
Extender
Actually I have the RBK 22 Orbi but I didn't see it listed. I am trying to get wifi on my dock which is about 45 ft away from the base Orbio and has to fo through two walls. I want to put an extender in my dock closet and I want it on the same network as my house is. What product do you recommend?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender
Exterior walls are the problem. If they weren't there, 45 feet wouldn't be that much of an issue. Extenders/satellites still need a decent signal to run off of.
what I'd try doing, is stand right where you think you'll be putting the extender/satellite. If you've got a decent signal, then you can add an extender/satellite there. If you don't, you'll either need to find a closer location or run a hardwired connection to the dock.
Once you figure out what tactic will work for you, then you can start looking at extenders vs access points vs satellites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender
Solved. I purchased Netgear AC Nighthawk WiIFi Mesh Extednder and I am getting a strong signal. Thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender
Please mark your thread as solved so others will know.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
