× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Firmware 1.12.0.18 turn off wireless by schedule setting disappear
Hi, everyone. Anyone can help to check this function for me. I don't know my Orbi got problem or this new version firmware removed.
Message 1 of 19
CaptStevo
Star
Re: Firmware 1.12.0.18 turn off wireless by schedule setting disappear
I'm in the same boat. My only guess is we'll have to downgrade. I am seriously unhappy that Netgear us *REMOVING* features from a product *AFTER* I bought it. Unbelievable...
Message 2 of 19
quentin
The scheduling function does not disappear
Just set the way to change
Is currently in stable use
you try it!
Message 3 of 19
Where can you find the way?  Can you tell me more details?  I can't find the way to set the schedule.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 4 of 19
superben79
Apprentice
"Just set the way to change
Is currently in stable use"
what does it even mean?
Message 5 of 19
quentin
I set the way
You can try!
Is this the way you want to set it?
Message 6 of 19
CaptStevo
Star
That's not it. There used to be an option to actually turn off the wireless radios themselves on a schedule.
The option you posted just blocks services and isn't available in AP mode.
Message 7 of 19
Oh Quentin, this is not I want.  I want to turn off wireless signal instead of block service...  Anyway, thank you for your reply. @.@
Message 8 of 19
They removed it. Only tech support had no idea! I have same issue. It's one of the reasons I bought the thing
Message 9 of 19
Patpat
Do we have any solution to turn on the wireless schedule off on the latest version? or we have to wait the next update version to see If this have been add it back
Message 10 of 19
Colmanlee
Guide
This is one of the reasons why I am buying this Router, can anyone from Netgear tell us whether this function will be available again?
Message 11 of 19
Supertramp11
Luminary
Re: Firmware 1.12.0.18 + 2.0.0.74 turn off wireless by schedule setting disappear
A quick confirmation of me having this issue as well in order to keep this thread on the first page of this forum and hopefully draws Netgear's attention.
Message 12 of 19
Ben_h
Initiate
Hi,
I was also really really disapointed when I realized the update removed the feature.  I don't want the wifi to be on at night.
Can you please re-enable the feature ?
Message 13 of 19
JMU1998
Luminary
Will this feature be added back to the next Firmware?
Message 14 of 19
3 Netgear will never answer you. The tech support doesn't even know that they removed the WiFi on off schedule feature.
Message 15 of 19
Ben_h
Initiate
OK, then I sent a tweet.  If tech support is not aware, at least commercials will be aware soon.  (Hoping that it won't be ignored by community manager).
Message 16 of 19
DarrenM
Sr. NETGEAR Moderator
Here is the current way to disable the wireless on a schedule
  1. Log into Orbi UI
  2. Go to Advanced -Security - Schedule
  3. Setup the time frame and days  on which they want to block internet access. See example below:
  1. Click Apply.
  2. Once schedule has been set go to Advanced - Security- Block Services
  3. Under Service Table section click on the Add button.
  4. On the Block Services Setup page use the setup below. If you want to block all but 1 IP you can configure the IP Address Range option and specify the entire IP range you want to block just make sure your IP is not part of that range if you do not want that specific IP blocked.
  1. Click Add, you will be taken back to Block Services page.
  2. On Block Services page select Per Schedule option under the Services Blocking section
  3. Click Apply.
  4. You internet access should now be blocked based on the schedule you set.
Message 17 of 19
Supertramp11
Luminary
Hi Darren,
I don't want to schedule the blocking of internet access, I want to schedule the switching on/off of the wireless radio. This is what this thread is about.
The menu (see attached) to do this completely disappeared.
Thanks for taking this further to your engineers.
Message 18 of 19
rancho
Initiate
Hi,
this is a very important/critical feature for me too. Could we pls have an update from Netgear/Darren about a possible ETA for the fix ? This would be good customer service...
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 10966 views
  • 21 kudos
  • 12 in conversation
Announcements
Orbi 770 Series
