- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware Problems w/ Satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
I updated the firmware on my router before I installed my satelite firmware update. It will not upadte the satelite through software or by doing it outside software. When I go to software update I get an error message "failed to get firmware version" and it stops at that point.
Could I just factory reset both router and satelite and start over or is there a better way?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
That .img file looks correct.
Did you unzip the file that you downloaded or are you trying to load it from within the zipped file?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware Problems w/ Satellites
Have you tried using manual update?
Select the satellite you want to update and then upload the update that you can get from here
- Mark as New
- Bookmark
- Subscribe
- Permalink
It says I am not connected to the internet. I am hard wired from router to computer. I can get on the internet anytime I want to setup as it is now. I am lost.
DO
- Mark as New
- Bookmark
- Subscribe
- Permalink
After going thru the manual install, it tells me the firmware version I am trying to install is incorrect, please load correct file and try again. RBS50-V2.1..img is the file populated in the correct box.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I resynced my satelite and when i logged in orbi it let update it automatically. It is working fine now..
Thanks for all the help could not have done it without ya.
