- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware Update Renders Orbi Unusable
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have had an Orbi system since 2017. It has worked perfectly. Then I got a notice to update the firmware. I did that and the Orbi became unusable. I could not connect to wifi. I disconnected the Orbi and ran an ethernet cable directly from my modem to my computer. It worked perfectly, so the problem was the Orbi. I reinstalled everything and it still did not work. After a couple of hours I decided the Orbi was junk. I disconnected it and bought a Google system. The Google system works perfectly. This will be last thing I buy from Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware Update Renders Orbi Unusable
Maybe post about this over in the correct Orbi AC forum.
https://community.netgear.com/t5/Orbi/bd-p/Orbi
SInce this is the Orbi AX forum.
There are some steps that may help recover the Orbi system.
Good Luck.
@Remraf wrote:I have had an Orbi system since 2017. It has worked perfectly. Then I got a notice to update the firmware. I did that and the Orbi became unusable. I could not connect to wifi. I disconnected the Orbi and ran an ethernet cable directly from my modem to my computer. It worked perfectly, so the problem was the Orbi. I reinstalled everything and it still did not work. After a couple of hours I decided the Orbi was junk. I disconnected it and bought a Google system. The Google system works perfectly. This will be last thing I buy from Netgear.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Orbi systems work just fine after FW updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
