× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Firmware update
dnh3155
Tutor
Firmware update
I have spent hours trying to do a manual update on the new firmware.  I have downloaded updates for the rbs into any possible place I can.  I browse for the update, and choose the image file to upload.  No matter where I choose the downloaded file from, I get the message that the file is incorrect. I’ve tried on my iPad and laptop, and get the same result. I get a message from NETGEAR to “check” for firmware updates, but that selection no longer works. I’ve read that the satellites have to be updated first, and can go directly to 32. That hasn’t worked, so I tried to go to 212 first.  No luck. Why does NETGEAR make everything so difficult?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 4
ekhalil
Master
Re: Firmware update
What is the file's name and extension that you're trying? Are you sure that you've correctly unzipped the file?
Message 2 of 4
Guru
Re: Firmware update
What FW is currently loaded?
What browser are you using? Try IE11 or Firefox or Opera.
Be sure you have a wired PC connected to the RBR.
Be sure your unzipping the .zip files to reveal the file needed.
Message 3 of 4
Blanca_O
NETGEAR Moderator
Re: Firmware update
Hi @dnh3155
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1146 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
