Orbi WiFi 7 RBE973
Reply
Google Chromecast will not connect to Chromecast - Non technical user!
Victoria222
Follower
I have an ORBI RBR50 - it will not connect to my Google Chromecast - If I flip over to my old Sky Router Wifi (which luckily I still have) then Chromecast work fine.
To be honest I have this issue with a number of wifi devices in my home when I try to use the Orbi RBR50, I am just about fed up with the entire system as susrely these things should be pretty much plug and play now a days.
I have emailed support at Orbi about some of my previous issues but no response.
I am not technical and to my knowledge should not need to be to set these things up.
The Orbi App says the security is expired but I do not want to spend $70 on this when the router does not work well anyway - if we have to spend this annually to use the ORBI it would have been nice to know before purcase of the router.
I am thinking of dumping the ORBI due to the fact it is so needy and the support so dreadful and buying Google Nest WiFi but I am worried this will not reach our garden studio where I work?
Idea or thoughts appreciated!
Thanks, Victoria
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Google Chromecast will not connect to Chromecast - Non technical user!
What is the Manufacturer and model# of the ISP modem the NG router is connected too? If there is a built in router here,
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Is the Orbi wifi using the same SSID name and PW as on the prior router? You can use this same configuration.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 997 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
