- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
HELP--I know there's a simple solution to this....
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm betting someone on here can help. I have had good success with my orbi to this point, we just moved to a new town, and got AT&T into the house. I have everything plugged in properly I've done it a dozen ways, but nothing works. The network that we used in our old place "appears" but you can't connect to it. The signal looks strong, and I believe the sattelite is working, but it's like it's not connecting to the new internet...ideas? My son says it's old tech and we should toss it, but it's a good piece of equipment I'd like to use it if I could...help, please?? Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: HELP--I know there's a simple solution to this....
@redheadin wrote:I'm betting someone on here can help. I have had good success with my orbi to this point, we just moved to a new town, and got AT&T into the house. I have everything plugged in properly I've done it a dozen ways, but nothing works. The network that we used in our old place "appears" but you can't connect to it. The signal looks strong, and I believe the sattelite is working, but it's like it's not connecting to the new internet...ideas? My son says it's old tech and we should toss it, but it's a good piece of equipment I'd like to use it if I could...help, please?? Thank you.
There is only one way to connect the Orbi: an ethernet cable from the WAN (yellow) jack on the orbi router to an ethernet jack on the ATT box. I would leave the satellite powered off until the network connectionis working.
An Orbi WiFi system will provide WiFi without being connected to the internet When you power up the Orbi WiFi (not cabled to anything), it should broadcast the WiFi signal and you should be able to connect to it. The device you connect will complain "no internet", but it still should connect. Start a web browser after connecting and open "http://orbilogin.net". The Orbi login screen should come up asking for the administrative credentials, "admin" for user name and whatever you have set the admin password to. (Not the WiFi password.) This should bring up the Orbi admin web interface.
If this does not work, something is wrong.
- Mark as New
- Bookmark
- Subscribe
- Permalink
RIght, I'd hate to think this expensive thing only lasted a year and a half, it just doesn't make sense. So I've tried to do this. It is already plugged in and completely properly and confirmed by several people that it's plugged in right. But whenever I try to get to the old network, it says it can't connect to that, I tried to do something with the original, tried scanning the qr code, I have no idea why it won't work, it' s like it's not talking to the AT&T interface.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, without being ON the Orbi I can't get onto the orbi network, I put in my admin and password and it comes up, looks like' your'e not connected" which I try to fix but it won't allow me, so I never get anywhere with the online interface. I have tried a couple of the numbered websites they go nowhere at all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does anyone out there know for sure that orbi will work with AT&T? I assume it would.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@redheadin wrote:But whenever I try to get to the old network, it says it can't connect to that, I tried to do something with the original, tried scanning the qr code, I have no idea why it won't work, it' s like it's not talking to the AT&T interface.
Sorry, sometimes it's best to double check. How are you attempting to connect "to the old network." When you open the network settings on a WiFi device, the WiFi name you are expecting to see is not there? When the Orbi was in use before, was it configured with a WiFi name different from the name on the product label (bottom of the case)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I changed the name, so the name expected DOES appear, but it's not connected to the internet. It is powered up properly and it's showing up on my selections for wifi, when I go there it says it can't connect or can't login. And then I'm stuck, because everything seems to depend on it's starting up with the hard wire to the new AT&T router. We have unplugged and replugged and given it time in between in a variety of different configurations and sequences.
- Mark as New
- Bookmark
- Subscribe
- Permalink
PS THank you for trying to help me. It's very frustrating to hear my kids say throw it away.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@redheadin wrote:Does anyone out there know for sure that orbi will work with AT&T? I assume it would.
Oh, yes. Plenty of Orbi's are connected to AT&T. It might be useful to identify specifically which AT&T service you have. (Apparently there are many).
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's an AT&T bgw210 router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994...
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/h...
- Mark as New
- Bookmark
- Subscribe
- Permalink
THank you for this, it helps because I do think that sometimes on macs some things are getting through and then other websites are being blocked, weird. Anyway, I'm not totally sure how to do what you're suggesting, but will send to my son and see if he's able to help me make this work and will explore online websites you sent along, in hopes one of them might assist as well. If you have more specific step by steps of course that's welcome.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For ease of setup, option #3 would be best.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for sticking with me on this. OK, I go to the website to set it up as an access (tried this earlier) and the second step or third is to log into orbi, of course I can't do that b/c my orbi router is not online eventhough it's plugged into the At&T router. So I can't get to the admin thing to do anything....so weird. Ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Look at the modems connected clients list, do you see the RBR listed there at all. If so, there will be an IP address listed. Can you access the RBRs web page with the given IP address in AP mode?
