- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Have to keep Wan on Static... If I don't I get Magenta and loose internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having a very weird problem... I'm on firmware V2.3.5.30. I have Optimum service & I'm noticing that if I leave my Orbi on DHCP wan within a few minutes I loose conecitvity / the orbi switches to detecting internet (Magenta Light)... If I go into the settings then switch the orbi to Static IP using what it obtained from DHCP it works. Thing is I don't pay for static so it is a DHCP service.. Why isn't the Orbi working correctly with DHCP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Have to keep Wan on Static... If I don't I get Magenta and loose internet
What is the lease time you get from your ISP?
You can find this in the web GUI under >> ADVANCED >> Router status
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since the FW update?
@computersteve wrote:I am having a very weird problem... I'm on firmware V2.3.5.30. I have Optimum service & I'm noticing that if I leave my Orbi on DHCP wan within a few minutes I loose conecitvity / the orbi switches to detecting internet (Magenta Light)... If I go into the settings then switch the orbi to Static IP using what it obtained from DHCP it works. Thing is I don't pay for static so it is a DHCP service.. Why isn't the Orbi working correctly with DHCP?
