Orbi WiFi 7 RBE973
Reply
Having issues with downloads
DarthThomas
Hi,
I recently got a RBK50 system with one sattilite. I have hooked up the system and everything is working ok except for my laptop. I am getting wifi on it but I can not do any updates on my windows, my kaspersky internet security or IPvanish. Can anyone help>
Message 1 of 8
CrimpOn
Guru
Re: Having issues with downloads
Can you please describe the situation in more detail.  The laptop connects to WiFi.  Ordinary activities like email, web browsing, printing, work correctly?  Only (1) Windows Update fails with an error code? (2) Kapersky antivirus does not update its database (with an error code?) and (3) IPVanish no longer allows you to reach the resources you use it for,
Or..... You use IPVanish for "everything" and "nothing works."
Thanks
Message 2 of 8
ekhalil
Master
The first thing I would think of in this case is multple routing.
Please do the following soimple test to check if you have multiple routers in your network:
Please open a Command Prompt on any computer attached to Orbi and type:
tracert 8.8.8.8  (or traceroute 8.8.8.8 if you're using a Mac computer)
  1. If you see two private IP addresses listed in the first two hops then you have double NAT. Please check the model of your ISP modem and if you have a manual for it.
  2. If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the root cause of the issue,
Message 3 of 8
CrimpOn
Guru
IPVanish has a whole series of support articles about how to get through routers.  One, for example, specifically how to deal with a "router behind a router": https://support.ipvanish.com/hc/en-us/articles/115002080193-Router-behind-router
Others talk about ports that need to be opened.
Message 4 of 8
DarthThomas
windows update - We couldn't connect to the update service.
kaspersky - doesn't say anything. It just starts then stops
IPV - An error occurred while sending the request.
Message 5 of 8
Guru
Can you temporarily disable Kaspersky and IPV?
Message 6 of 8
DarthThomas
Arris Surfboard SB6183
Message 7 of 8
Guru
Try powering OFF the ISP modem for 1 minute, then power ON and let it sync, Factory reset the RBR and setup from scratch with a wried PC.
Disable all security software programs temporarily on the PC.
Test for speeds and internet downloads.
Try different browsers and different devices...
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1482 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
