× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Help Orbi Satellite Connection Type is 2.4ghz in my RBR20 and RBS20
NanoSuit
for some reason my orbi keeps Connecting to 2.4ghz , so how do force it to stay on 5ghz ?
my devices connect 5ghz but my satellite stays on 2.4ghz and it halves my connection speed.
and thanks in advance.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 13
tomschmidt
Virtuoso
Re: Help Orbi Satellite Connection Type is 2.4ghz in my RBR20 and RBS20
It sounds like your satellite may be too far from the router.  How far are they appart?  Depending on building materials of your house, try having them about 30 feet (10 meters) apart.
Message 2 of 13
NanoSuit
my router is literally in the next room.
Message 3 of 13
Guru
And what materials are the walls?
5ghz can't penetrate as much material or certain materials.
Message 4 of 13
NanoSuit
concrete, but my huawei 5g cpe pro 2 can penetrate it and it is what i am connecting my orbi to.
Message 5 of 13
Guru
1. Concrete is literally the material (other than straight metal) that blocks wifi the best.
2. the huawei 5g cpe pro 2 is a wireless AX router. Not a AC device
3. the orbi uses the better connection. 5ghz doesn't passthrough materials as well as 2.4ghz. yes the 5ghz might passthrough but if the 2.4ghz is faster, its going to use that one
Message 6 of 13
NanoSuit
is there anyway around it ?
like can i make it so the Satellites connect to 5ghz only ?
Message 7 of 13
CrimpOn
Guru
The most obvious solution is a masonry drill bit to punch a hole through the wall in an inconspicuous place to use ethernet cable to connect the satellite to the router.  There are telnet hacks to turn off individual Orbi radios, but my understanding is that the satellite 2.4G "fallback backhaul" uses the same radio as the front-facing 2.4G service. (but with a 'hidden' SSID)
The Huawei appears to be an awsome device.  ($670USD) The feature list suggests expanding coverage by connecting Huawei WiFi access points, but does not mention any specific model numbers.https://consumer.huawei.com/en/routers/5g-cpe-pro-2/
Message 8 of 13
NanoSuit
I don't want to drill my wall or use hacks.
then i guess i am stuck with 2.4ghz until i find a better device for penetrating walls, does anyone have a suggestion for a device to replace my RBR20 and RBS20 ?
and thank you for all your replies, and for trying to fix my problem .
Message 9 of 13
CrimpOn
Guru
Any idea how thick this concret wall is?
Message 10 of 13
NanoSuit
I really i'm sorry for taking too long to reply,it is around 1 feet or 10 inches.
Message 11 of 13
Guru
You could try using powerline or a moca adapter to hardwire in the RBR to the RBS.
Message 12 of 13
NanoSuit
I can't use the moca adapter because i don't have a cable, i will try the powerline then i will reply with the results.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 2139 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
