×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
How To Enable Remote Management on Orbi RBR850 with New Firmware V4.6.3.16_2.0.51
MGWAPs
Hi, we updated our Orbi RBR850 firmware to V4.6.3.16_2.0.51 but can no longer enable REMOTE MANAGEMENT.
Is there a way to enable remote management now on this router with this new firmware???
Thanks
Message 1 of 4
Accepted Solutions
Guru
Re: How To Enable Remote Management on Orbi RBR850 with New Firmware V4.6.3.16_2.0.51
Thats enabled on the Orbi app and is now called Anywhere Access.
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
We have updated and published a new KB about it:
https://kb.netgear.com/000058239/How-do-I-enable-or-disable-Anywhere-Access-on-my-NETGEAR-or-Orbi-ro...
https://kb.netgear.com/000064332/Why-is-Anywhere-Access-enabled-by-default-on-my-NETGEAR-or-Orbi-rou...
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
All Replies
Guru
Good Luck.
Thank you
Message 2 of 4
MGWAPs
THANKS!  This was very helpful
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 636 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
