merlinca
Mar 05, 2019Follower
How do I change my Orbi RBR40 from 5.0 ghz to 2.4 ghz in order to connect to my weather staion?
I purchased a LaCrosse weather station and it requires a 2.4ghz. connection, at least during setup. Can anybody tell me how to change my Orbi RBR40 mesh network to 2.4 ghz. from 5.0 ghz., at least temporarily?
The Orbi broadcasts both at the same time. So the Device will only see the 2.4Ghz radio if thats all it supports.
If your setup mobile device is needed in addition to setup the weather station device, you can lower the power output of the 5ghz radio so that the setup mobile device connects to the 2.4Ghz radio instead of the 5ghz radio. This is a problem with the device Mfr, not with Orbi.
- ekhalilMaster
Please check this post: https://community.netgear.com/t5/Orbi/Orbi-Home-Wifi-amp-LA-Crosse-Weather-Station-Alarm-Clock-2-4GHz/m-p/1680357/thread-id/48008
