Erwin_S's avatar
Erwin_S
IPv6 on rbr50
Hi,
I'm trying to het IPv6 working on my setup.
My ISP provides IPv6, but when I want to enter the IPv6 settings on my Orbi, all is grayed out.
When bypassing the Orbi, directly on de ISP modem (ethernet of WiFi), then all IPv6 tests run fine, so IPv6 is there.
The Orbi is in AP mode, with FW level 2.7.3.22 connected to a FortiGate 60e firewall with the latest FW level.
Devices connected directly (ethernet) to the FortiGate are provided with IPv6 connnectivity.
DHCP is provided by the FortiGate, which has all the correct IPv6 settings enabled.
I would like to know what caused the setting to be grayed out.
Any clues?
Erwin
