- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ISP speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
ISP speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ISP speeds
Yes. It appears that both the CM1200 modem and the RBK750 router support "Link Aggregation" which provides more than gigabit speed between modem and router. Check the User Manuals for modem and router:
https://www.netgear.com/support/product/cm1200.aspx#docs
https://www.downloads.netgear.com/files/GDC/RBK752/RBK752_UM_EN.pdf
search for "Link Aggregation".
Netgear has set up a community forum specifically for the "AX" Orbi products. It is more likely that someone who owns the CM1200 or RBR750 will notice a post in that forum than in this one. The AX forum is here:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ISP speeds
My question is, what is the maximum speed tier form my ISP that my RBK753 can support.
In other words, I have 1.2gbps service from comcast. Will my equipment support this speed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ISP speeds
@plemans wrote:@CrimpOn did answer the question. wan link aggregation supports speeds of up to 2gbps. Whether your wireless devices can support that speed is another matter. Usually at these speeds the bottleneck is the wireless devices and not the router.
Well, sort of. These two products together advertise a total maximum capacity of 2gbps by combining two gigabit links. Whether the router is actually capable of processing 1.2gbs of traffic through the router to devices under real world conditions depends on many (many) factors, such as how devices are connected (WiFi vs. ethernet), how many are connected through the satellite WiFi backhaul, etc. That is why I suggested posting the question in the AX product forum. There is a chance that some customer has already signed up for 1.2gbs service and conducted experiments to validate the claim.
One obstacle comes to mind immediately. When people discuss the ability of the older Orbi products to handle gigabit service, they usually connect a computer directly to the modem for comparison. I am not aware of computers with multiple gigabit ethernet ports that support link aggregation. If they exist, I doubt very many peope have them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ISP speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ISP speeds
are you sure it wasn't a TB?
Comcast increased their data cap from 1 TB to 1.2TB
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ISP speeds
Plus its tough to test a 1.2gb connection.
I have a setup currently that allows it but if you're using the RBK and using wan port aggregation, you're already using the max wireless connection. About the only way to hit 1.2gig is to saturate the wired line while testing wireless on another device.
I've done that with my arris AX11000 (wan port aggreation is its max connection). I managed to hit around 1.18gig
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ISP speeds
We're excited to share that we're increasing your download speeds from 1 Gbps to 1.2 Gbps. Faster download speeds help to give you a better experience as you work, learn, and stream from home
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ISP speeds
Have you tried testing it with a wired connection and a wireless device at the same time (2 seperate devices)?
Also, use comcasts speedtest site.
