- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Installation
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure that I get this bit:
@Hsilva92 wrote:
....everytime I try to install and connect it asks mentors connect to the network however I do not have the password to his network..
You do not need to go through all that registering process if you simply want to set up the Orbi on your own network.
To remove any settings for network name or password for the previous owner's wifi, you just need to factory reset the device and go through the setup process described in the documentation. The reset will put everything back to the defaults that are on the label on the bottom.
There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
The easiest way to set this up is probably to use the web browser, as described in the Quick Start Guide.
When the thing is working, you might get help with registering it to your account from one of the Netgear team here.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
@Hsilva92 wrote:
Hello I purchased a used orbi rbk 50 on amazon..the previous owner never gave me his network name or password, everytime I try to install and connect it asks mentors connect to the network however I do not have the password to his network..how can I set up a new network name and password? I called tech support and they asked me to email them proof of purchase and a case number so they can transfer the serial number to my name..however I need wifi asap and I'm not sure how long it will be before they email me back..any advice?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
Ok, What is the Manufacturer and model # of the modem the Orbi is connected too? There maybe a modem box near by that the Orbi is connected to, or may there is just a wall outlet where your plugging the Orbi base into the wall?
@Hsilva92 wrote:
Sensei furry I'm sorry but im not sure where to find that information you are asking..I'm still learning these terms forgive my ignorance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
Glad that worked out.
You might now want to start the process of getting the thing registered to you.
Best start a new discussion for that. Then we can point it at the people here who manage those things.
First create a MyNetgear account, if you haven't got one already.
You will need that to use some of the add on features of your Orbi, such a remote access. But for day to day use you don't need it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
