Orbi WiFi 7 RBE973
Reply
Internet Offline for RBR20
ginas
Can someone tell me what could be causing the Internet Offline issue? I have an RBR20 Orbi with one satellite. Just started having issues with internet last week after a year and a half. I have rebooted my Spectrum model and Orbi Wirelss Router numberous times. I have worked with Spectrum to make sure everything works correctly with their modem. If I use the Spectrum wireless modem they provided I have no issues. But when I switch to my Orbi we are getting Internet Offline. We have issues reaching apps on our Smart TV and accessing numberous websites.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 11
Accepted Solutions
Guru
Re: Internet Offline for RBR20
Ok, just checking to see if your modem had a built in router or not, it doesn't:
http://www.dslreports.com/r0/download/2360837~07f40bb37d0d67c6fd10be3e77d72927/E31_2V1%20Data%20Shee...
Power OFF the modem for 30 seconds then back on. While this is happening, press the reset button in back of the Orbi RBR for 15 seconds then release. Use a wired PC and web browser and walk thru the setup wizard at 192.168.1.1. This should help you get the RBR connected.
Be sure to use a good quality LAN cable. Swap out. CAT6 is recommended.
@ginas wrote:
Sorry I just logged into my Spectrum account and found this info on my Modem.
Manufacturer
Ubee
Model
E31U2V1
Message 10 of 11
All Replies
ekhalil
Master
Do you get this issue intermittantly? Do you see a purple LED on the RBR20 when this happens?
If the answers are yes to those two questions, then most likely your issue is similar to this: https://community.netgear.com/t5/Orbi/Another-RBR50-Dropping-Internet-Connection/m-p/1875385/highlig...
Please try the suggested solution in that post.
Message 2 of 11
ginas
The issue started last week and has been the same since it started. It is not intermittent. The lights on the router and satellite are like normal - they are not purple.I am able to access the apps on a laptop but not on the TV. The wesbite ittes happens on all devices. Orbi shows connected in my app but the Internet says offline.
Message 3 of 11
Guru
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Message 4 of 11
ekhalil
Master
What Spectrum modem/router do you have in front of Orbi?
Message 5 of 11
ginas
It is a PC20 ... is there any other info you need on it?
Message 6 of 11
Guru
This doesn't seem to match a modem model or Manufacturer name.
Can you be more specific about the modem model# and it's manufacturer? Or is the Orbi router connected to a wall jack?
Message 7 of 11
Albiston
Configure the modem for transparent bridge or modem only mode. ...
If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem.
Message 8 of 11
ginas
Manufacturer
Ubee
Model
E31U2V1
Message 9 of 11
Guru
Manufacturer
Ubee
Model
E31U2V1
Message 10 of 11
ekhalil
Master
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3858 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
