× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Internet connection via Wifi router is intermittent even though ethernet connection works
PatricksMadison
Follower
Purchased my Orbi RBR-50 router with two satellite RBS-50's in February 2019. The RBR-50 is ethernet connected to a Motorola MB8600 cable modem and several other devices but not to the RBS-50's. It's current firmware is V.2.5.1.16.
About two months ago the Internet connection via Wifi began failing intermitently for minutes at a time even though the ethernet connectivity to the Internet was intact. Devices connected via Wifi such as printers and iPhones were fully functional but could not access the internet. Rebooting the RBR-50 would restore the connection but not every time. I powered off the two satellites for solo operatation of the RBR-50 but had no change. Sometimes, normal operation would last for hours but then begin to fail intermittently. My WOW ISP indicated no network problems.
Internet speed test is almost 350 megabit per second through ethernet and about 200 megabit per second via Wifi when it's functioning. But, I cannot trust it for normal, reliable operation at this time.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Internet connection via Wifi router is intermittent even though ethernet connection works
Has a factory reset and setup from scratch been performed since last update?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 448 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
