- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issue with my Orbi Satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
So wondering if someone can help me on this. My orbi satellite has been acting up recently not broadcasting wifi. Before I get into it, I have power cycled the router, the satellite, the router and the satellite, I have updated firmware manually, reset to factory defaults... twice, all to no avail... Also I know the satellite was not bum off the line because it worked fine in the past for some time (I've had the system for close to 6 months with no prior issues).
Anyways, the issue appears to be the satellite has wifi "disabled" but I can't find a way to turn it on (no switch on the hardware, no option when logged into the satellite through either its direct IP admin page or through the router admin page). Going in through the router admin page shows the satellite as a "connected device" but doesn't recognize it as a satellite. Further, reseting the satellite and synching manually yields a blue light (never magenta) but still the router page doesn't recognize the satellite as a "satellite" - only a "connected device". And finally, logging into the admin page for the satellite itsefl yields a picture showing the satellite connected to the router, but specifically stating the wifi for both the 2.4 and 5.0 channels as "disabled". Anyone have any ideas? Its really quite frustrating, especially how expensive these units are and the amount of time I've had it.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issue with my Orbi Satellite
Updated to Firmware 1.12.0.18
- Disabled the WiFi radios on Satellite. (WTF, seriously NetGear?)
Fix:
1. Manually uploaded previous Firmware 1.11.0.20 **Satellite Version, This is IMPORTANT** to Satelite manually via ip address (of your Satellite) in Web Address.
2. Manually uploaded Firmware 1.11.20 **Router Version, This is IMPORTANT** via web-portal.
-- This worked for me. Not sure if it will for you. Just sharing. Good luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had same problem - latest firmware update appeared to knock out satellite. Satellite showed in the web interface as a device, not as a satellite, and was showing as "disabled" when accessed via its IP address. Rolling back firmware worked.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now, for the logical next question - can you disable automatic firmware upgrades?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why is this even still on their servers?! Netgear get it together, either fix the satelite firmware or remove the bad update so that we can roll back without having the broken update forced down our throats. Amateur hour....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Ucchi - that has stopped me returning the Orbi.
Netgear - Seriously concerned this made it through QA.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It has been a month, 6 downgrades to the firmware that works and 6 forced auto updates to the broken firware. This is so ridiculous and I regret every dollar spend on this subpar product.
- Mark as New
- Bookmark
- Subscribe
- Permalink
