× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Issue with satelite - not connecting, not resetting
gui83
Follower
Hello,
I have a mesh solution with 2RBS20 + modem. Everything has been working perfectly for 12 months - but suddenly one of the satellites stopped working. It shows as "not connected" on the app and the light (next to the power button) is bleaking amber (10 flashes, then a pause). I have tried to reboot and did multiple attempts of  factory resets. Nothing is working. The amber light keeps bleaking and it does not work.
Thanks a lot for your suggestions !
Message 1 of 2
Guru
Re: Issue with satelite - not connecting, not resetting
Be sure the RBS are using same version of FW as the RBR.
Did the RBS appear on the RBRs web page?
Press the back reset button for 15 seconds then release. Then try to sync the RBS.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 366 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
