- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issues with Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Issues with Orbi
I have been having few issues with Orbi and they are listed below:
1) Over the last 4 weeks I have had to reset my router to factory settings 3 times as it would show connected but no throughput/traffic.
2) I havwe been using Open DNS settings for parental control and ever since 'Disney' parental control got launched the parental control settings get diabled on their own. This is even more nafelling as the admin rights are only with me and so dont know how they defaault to some state.
I have a case open with netgear ( 40544774) but the issue is not resilved yet.
Any comments or suggestions as both these obeservations have the first of its kind for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issues with Orbi
I am not sure if your respense pertains to issues i am facing....if not could you elaborate
- Mark as New
- Bookmark
- Subscribe
- Permalink
1)
- When this happens do you see no throughput in all devices?
- What type of devices?
- Have you tried to only switch off/on wifi on the devices to see if this restore the issue? Have you tried power recycle on the router/satellite? Why did you need to factory reset?
- When this happens, how does the radio conditions in the surrounding look like, can you use a wifi analyser to see the active channels and the strength of each? Any neighbor's channels that are same as yours?
- Do you have any wired devices connected to your Orbi's?
- Do you have wired or wireless Backhaul? Is Daisy Chain activated?
2)
I had the Disney Circle issue you described frequently in the beginning. I did not see it after updating to 2.2.1.210, which FW are you on now?
- Mark as New
- Bookmark
- Subscribe
- Permalink
1)
- What type of devices?- kaks- they show connected but no traffic
- kaks- tried it buit did not make a diffrence, even power cycled the router but still no connection, ended up doing a factyory reset
kaks- all are working fin and infact i never had thius issue with any of the earlier rourtres...
kaks- yes
-kaks- How do i activate it, i did see it is et us a rouer when i logged in and checked the web but it says downlink speeds decrease , dont see the reson why
2)
kaks- no firewall but issue still remains and my firmwares is V2.2.1.210
- Mark as New
- Bookmark
- Subscribe
- Permalink
When connected does the device have IP addresses starting with 169.25.......?
kaks- yes
What wired devices do you have? Connected to Router or Satellite?
When you say "the parental control settings get diabled on their own.". Where do you see that the settings were disabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@kaks Please have a look at this https://community.netgear.com/t5/Orbi/quot-Wifi-Disconnection-quot-issues-are-still-in-2-2-1-210/m-p.... If you have wired devices please check them. Test to disconnect them and see if the system will perform better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
It suck payoing so much for the mesh router and have these issues and netgear doing the dance on not achnoloeding that we have an issue here...
some how still feel it is hardware issue...
Further just 10 mins back all my wifi went off and so after the reboot am online again....
expect a better product and support from netgear....
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275...
Try this as well:
@kaks wrote:
Thanks
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
