× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
It's the Orbi invocation of SpeedTest that's generating mystery traffic!!!
JamminJimmy
Guide
It's the Orbi invocation of SpeedTest that's generating mystery traffic!!! Has to be!!! in my case, I see the spike at the exact time that my Orbi reports it last ran the speed test. In my case, running about every 2 hours, that's consuming ~30% of data allotted to me by my ISP! I can't believe that the frequency of automated speed test execution is configurable! I get that it should run at least once / day, but it shouldn't be the primary consumer of my (ISP-limited) bandwidth.
Message 1 of 4
Re: It's the Orbi invocation of SpeedTest that's generating mystery traffic!!!
Message 2 of 4
JamminJimmy
Guide
Excellent question and it has triggered a thought.
Yes, it's that grafana. It's in a Home Assistant instance. It gets the data from the Traffic Meter feature of the router, which is coming from the Netgear integration with HomeAssistant. Your question made me think about that so I started digging through their docs. This bit is especially interesting, particularly the note of warning at the end of the paragraph. I know that I disabled the downlink and uplink entities long ago, but I don't remember doing anything with the ping entity. So, if that's still enabled in HA, then the integration is still running the full speed test every 2 hours. I may be taking an extended lunch break to head home and verify if any one of those 3 entities are still enabled and if so, I'll disable it and unblock access to speedtest.net. Assuming that 1) I don't see a spike in network traffic every two hours and 2) the last updated field in the Admin pages of the Router management remains unchanged, then I think we've found the culprit. It's also interesting to me that the HA integration might be updating the last run time value of the Speed Test results page in the router's management tool -- but if it's a true integration and invoking speed test as offered by the router, then it makes sense.
If this is the issue, which won't surprise me at this point based on those docs, my frustration with lack of configuration flexibility persists, but will have moved from the Netgear product to this 3rd-party integration with the product. I'll share updates here hopefully later today when I get hands-on with it to check the state of the 3 named entities that would trigger the speed test.
Message 3 of 4
Have you looked at your router's logs? That should offer a few clues.
Orbi devices seem to be designed to be "bullet proof" and easy to set up and manage. In the process this removes many of the controls that you can get with Netgear's other Mesh routers like the MK range.
Experienced users might do better to down that road than the Orbi route, although these have also changed over the years to add a few more bells and whistles.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 303 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
