- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
What's the ping latency between client/Satellite/Orbi/ISP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
Are you wireless or wired when gaming?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@James_Wheelz wrote:
My orbi setup has high latency making online gaming almost impossible. How do I lower latency? My computer shows my latency averaging 158ms.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
Disabling some of these features is a troubleshooting step to see if anything changes for you. Armor and security features can slow down or cause latency.
You may want to update FW to v2.5.1.8 aswell.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
Fast roaming and Circle are off. Why would I turn off daisy chain since I have the router and 2 satellites? Also why would I disable Armor?
Daisy Chain makes it possible for a satellite to connect to the router through another satellite, rather than directly. If the satellites are physically located "around" the router, rather than one satellite being farther from the router in the same general direction as the first satellite, then Daisy Chain won't be used. However, Daisy Chain causes the satellites to create another 5G WiFi channel for the Daisy Chain which is "wasted effort" if it isn't used. Netgear ships Orbi's with Daisy Chain enabled so that customers can add another satellite and it will "just work" no matter how it is physically located.
So, if your two satellites need Daisy Chain, then you have to keep it on. If they do not, there is no harm in turning it off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
I have to play on wifi it's not my choice.
Since this issue is a serious frustration, you might consider temporarily relocating the computer to where it can be plugged directly into the modem. (i.e. unplug the Orbi and plug in the computer). This takes the Orbi completely out of the picture. If the on-line game reports serious latency issues when the computer is plugged directly into the modem, then the Orbi is not the cause.
As you may have read, people have reported issues with firmware 2.5.0.38 that is installed on your Orbi, both in terms of features and performance. Many users have reported manually "going back" to firmware 2.3.5.30 or manually installing 2.5.1.8. A manual isnstall is probably less time and effort than hauling a computer across the house and back.
2.3.5.30 is available here: https://kb.netgear.com/000061080/RBR50-RBS50-Firmware-Version-2-3-5-30
2.5.1.8 is available here: https://kb.netgear.com/000061530/RBR50-RBS50-Firmware-Version-2-5-1-8
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
We experienced members ("old farts") are really comfortable with an honest "hard wired" connection. I see no reason why a firmware update cannot work over WiFi. When the Orbi reboots, of course, the WiFi connection will drop. If things go correctly, then the WiFi should come back, the computer should connect automatically, and the web page might even refresh. (hmmm, probably want you to log in again.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
Because if I upload just RBS50-V2.5.1.8.zip it doesn't work.
This is absolutely correct. The files must be "extracted" (I call it "unzipped") first.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latency
Were you able to connect the X-Box directly to the modem temporarily as a test?
I know this is going to sound crazy, but I purchased a LONG ethernet cable that reaches from my modem to the farthest room in my house. I wait until the family is out of the house, and then string the cable wherever I want to test something. That's how I verified ethernet backhaul works and tested latency on my setup comparing wired vs. WiFi backhaul. I mention this because it just occured to me that the X-Box requires a television set (duh!) Relocating an X-Box is trivia, but moving a TV set may not be possible!
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
