- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Loss of connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Loss of connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Loss of connection
Hi @piperd,
Have you tried running a speed test hard wired directly to the ATT router? If so, what were the speed test results?
a) If the issue is still the same during this testing phase, you would need to contact your ISP.
b) If speed test results are better when hard wired to the ATT router, then hard wire the Orbi router and provide your speed test results.
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would suggest contacting your ISP as you are still getting very slow speeds when you have your desktop hard wired to your ATT router. Feel free to provide an update once you're able to get in contact with your ISP.
Best regards,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Next option would be 2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
