Orbi WiFi 7 RBE973
Reply
MU-mimo, beamforming disabled
mith_it
Luminary
Why aren’t these enabled by default? Sounds like these are some of the features someone buying an Orbi system would be looking for
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 2
Accepted Solutions
st_shaw
Master
Re: MU-mimo, beamforming disabled
"Implicit Beamforming" is a compatibility setting to accommodate older devices that do not conform to the 802.11ac standard. It's not a high-performance setting.
https://www.howtogeek.com/220774/htg-explains-what-is-beamforming-on-a-wireless-router/
MU-MIMO is unlikely to do anything beneficial and may reduce throughput.
https://www.smallnetbuilder.com/wireless/wireless-features/33100-why-you-don-t-need-mu-mimo
Try them ON and OFF and use what works best for you. I have them both ON, which used to be the default in early Orbi firmware, I believe.
Message 2 of 2
All Replies
st_shaw
Master
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 11542 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
