- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Magenta! Add-on Outdoor Satellite(RBS50Y) won't sync with RBR850 - Orbi Tri-band Mesh WiFi 6 Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Greetings! I've followed all directions and troubleshooting tips but I can't get my new Orbi add-on satellite (RBS50Y) to sync with my Orbi RBR850 mesh wifi router. I had no trouble setting up the router and the satellite that came with it. But when I try to sync the RBS50Y I get the Magenta light indicating failure to connect. I've tried everything suggested by the documentation.
I need to set this up to teach a class starting Tuesday. Would be grateful for any help! Carol
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Magenta! Add-on Outdoor Satellite(RBS50Y) won't sync with RBR850 - Orbi Tri-band Mesh WiFi 6 Rou
I would first attempt to sync the RBS50Y in the same room with the Orbi router. It is a lot easier to see what is happening when all the devices are in the same location. The User Manual on page 12 indicates that "pulsing magenta" means the sync button is disabled, and "solid magenta" indicates it did not connect.
http://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_UM_EN.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, I've done all these things! There seems to be a deeper issue not covered by the documentation. But thanks for the quick response! 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Like other Orbi's, the satellite has a tiny "Reset" hole on the back. Since the satellite appears to be "DOA", it cannot hurt to try resetting it to Factory.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Alas, I tried that, too! but thanks for the suggestions -- all make perfect sense, it's just a weird situation!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I thought I read on these forums that currently the WIFI5 (802.11ac) satellites currently do not work with WIFI6 (802.11ax) systems like the RBR850, at least for their backhaul. Is that corrected now in the WIFI6 firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh, d**n. Once again, I failed to read carefully. You are correct. Netgear has promised that WiFi5 satellites will eventually sync with the WiFi6 product, but NOT YET.
So, maybe it is time to try the "other mode" on the outdoor satellite? (The one where it will connect to any WiFi router.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh gosh, how could I have missed that! That must be the explanation. I should have investigated more carefully before purchasing. Thanks so much!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, that's a great idea, I'll pretend it's not an Orbi router. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately any RBS50 series satellite is not yet wirelessly complatibe with the Orbi AX system. NG has mentioned that at some point they will be makiing them compatible. No time frame or when this will happen.
For any Orbi AX support or information, please post in the Orbi AX forum here:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
