- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Multiple 2.5.1 Firmware Updates?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, i have a question regarding the 2.5.1 firmware update. I have an Orbi router with 3 Orbit satellites and the Orbi app indicated that an update needed to be done. But the update runs multiple times as if it hasn't been completed. Is this because the update has to run once for each of the ORBI components of my network (i.e. 4 times)? I've run it 4 times and when i look at the details for the various ORBI units, only 2 of them are at 2.5.1. The others are 2.3.5.30.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Best way to ensure FW is updated correctly is to manually download the FW files:
Update the RBS first then RBR lastly. You can apply FW updates on the RBS web page.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Multiple 2.5.1 Firmware Updates?
Thanks Furrye38!!! I accessed my router through my Mac's browser instead of my iPad (using the app) and i was able to get to the manual update. And as you indicated, running the update from there fixed the problem. All my devices are at the 2.5.1 now. Thanks for all your help! Much appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
