- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NAT Stopping FTP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi folks.
I've been trying to use FTP downloads to my PC but can't get the data connection to work.
It was working fine when I had a DGND3700 but when I changed to Orbi the problems started.
Through working with guys on help forums, it seems the Orbi stops the data connections NAT style.
Does anyone know how I can bypass any restriction?
I've added the ports to the forwarding section already.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
After managing to borrow another router I found it wasn’t the NAT that was causing the problem.
I did however find it was due to some bad coding in my server.
Thanks for the help
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NAT Stopping FTP
What orbi model system do you have?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the quick response.
It's an RBR50 with V2.7.4.24
There's no model number on the modem but it's supplied by Virgin Media.
However it's the same one that worked ok with my last router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would need more information on the Virgin Media modem. Most of these have a built in router which could cause problems. Need the model # to verify this...
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is a modem/Router but the router is disabled.
The datails I can get from it is: Hub 3.0
Hope this helps
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would be good to know what NG router you are referencing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
