Orbi WiFi 7 RBE973
Reply
NETGEAR Orbi RBK50 Satelite Question
HOFB
Will the Orbi RBK50 satellite withstand cold temperatures. If so, how cold???
Message 1 of 4
Accepted Solutions
Guru
Re: NETGEAR Orbi RBK50 Satelite Question
Per the specs in the manual, its rated in temps from 32-104 degrees F.
I've had mine in the garage in the winter time where it gets below freezing and it still worked. Its not ideal and is going to cut its lifespan down. Reason why is you have something out doors getting hot/cold and that can caues moisture buildup (enemy of electronics). So it might last years (like mine) or just days.
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 4
All Replies
This place is for Mobile Routers, Hotspots & Modems. You might get more help if you ask this question in the place where Orbi users hang out.
Orbi - NETGEAR Communities
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
Guru
Message 3 of 4
HOFB
Thanks for that info. I appreciate your feedback. Like you, I guess I'll take that gamble and leave it in my unheated shop. Thanks again..
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 663 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
