× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
NETGEAR Orbi Router RBR20
Jenn1949
  • I need some helpI have an orbi rbr20 and need to change my zoom 5363 from a router modem to just a modem.
  • can anyone advise me on how I can make the modem connect to the orbi once I get help chan ging from m odem router to a modem
  • Thank you for your reply
Message 1 of 3
CrimpOn
Guru
Re: NETGEAR Orbi Router RBR20
Here is a link to the user manual: http://www.zoomtel.com/documentation/cable/5363-UserManual-Eng.pdf
On page 30, it shows how to log into the modem:
I believe it is on page 95: "Primary network bridged".
There is also a menu for turning off the WiFi system
Good Luck!
Message 2 of 3
Other way round. Install the modem then get the Orbi to connect to that.
It is usually best to reset the Orbi to its default factory settings and set up the Orbi from scratch.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 458 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
