- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Need an ethernet port for NVR in room without an Orbi Satellite [RBR/S50 mesh LAN]
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hardware: Orbi RBR50 Router with 6 Orbi RBS50 satellites
Need to setup an CCTV NVR that requires an ethernet port for WiFi in a room that does not have access to one of my 6 Orbi Satellites to plug into. Since I've already maxed out the number of satellites that I can connect to my system, is there anyway I can use a WiFi extender with an ethernet port to provide the connection I need for the NVR? If so, what extender works best with an Orbi mesh system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Need an ethernet port for NVR in room without an Orbi Satellite [RBR/S50 mesh LAN]
Any brand of extender (from any company) that has an Ethernet port will work. I have had success with the TP-Link PE220 ($20 on Amazon). Connect it to the Orbi WiFi network and plug the NVR into the Ethernet port.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your answer. I've ordered one and I'll let everyone know if it works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
An alternative would be Powerline Ethernet. It turns the electricity circuit into Ethernet. Works well as long as your main circuit isn't too "noisy". Can be better that wifi and easier to setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My limited experience with Powerline is that it can indeed work beautifully, or it can be unreliable and frustrating.
When two devices are on the same electrical circuit, Powerline can be awesome. Once the signal passes through the electrical panel through two circuit breakers, performance can drop significantly. Currently, I have a Tivo video recorder and Tivo Mini remote networked to each other and the internet through three Powerline adapters. Tried a fourth adapter in the garage to network some security cameras and it would work for a random period of time and then "turn red". The process of getting that adapter working again involved crawling under furniture and going up/down stairs and I got fed up with it. Installed an Orbi satellite in the garage instead.
Many homes have coaxial cable running throughout the house from when it was common to include connections for cable television in most rooms of a house. Multi media over Coax (MoCA) adapters can provide excellent data networking. I used MoCA for several years and it was rock solid. Did not like the rat's nest of coax behind the Orbi router and went to Powerline.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sums up my experience. Works well for when you want to connect a TV to a "local" router without the pain of using wifi. Also good at providing wired backhaul for an AP on the same circuit. Hopeless at jumping a fuse box.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
