- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Need to reboot RBR50 every couple of days
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Orbi system is having issues maintaining optimal speed. I have a 300+Mbps tier from Xfinity. The speed performance over wifi noticeably decreased to less than 50Mbps by the satellite. What seems to fix the issue is rebooting the router. The Wifi speed returns to over 300Mbps for several days. But invariably, it doesn't last. Several days later the speed will drop and I'll have to reboot the router again. Is there any permanent fix for this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Need to reboot RBR50 every couple of days
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@markgriffith11 wrote:My Orbi system is having issues maintaining optimal speed. I have a 300+Mbps tier from Xfinity. The speed performance over wifi noticeably decreased to less than 50Mbps by the satellite. What seems to fix the issue is rebooting the router. The Wifi speed returns to over 300Mbps for several days. But invariably, it doesn't last. Several days later the speed will drop and I'll have to reboot the router again. Is there any permanent fix for this?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
