× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Negear Orbi (RBK50) Device List showing the same device 18 times on both mobile app and Web page.
schooner16
Negear Orbi (RBK50) Device List showing the same device 18 times on both mobile app and Web page.  I have the latest firmware and the behaviour seemed to start after a power outage.  Now everytime I login the app I can see the count of my devices and but when I expand to see details it shows the same device all 18 times.   The connectivity seems great still but its fustrating not being able to see what devices are connected to the mesh network.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 8
Accepted Solutions
Guru
Re: Negear Orbi (RBK50) Device List showing the same device 18 times on both mobile app and Web page
Try resetting the RBR first. Turn OFF the RBS. Reset the RBR and setup from scratch. Check to see if you device is listed again multiple times.
What is this device that appearing multiple times??
Message 4 of 8
All Replies
Guru
What is this device?
Has a factory reset and setup from scratch been performed since last update? If not, lets try this...
Message 2 of 8
schooner16
Firmware: Is latest v2.5.1.8
Device: Negear Orbi RBK50(router and satelite)
I have not did a factory reset.  I should do this right after the firmware was upgraded?  Seems extreme but will do it.  Factory reset on Router or both router and satelite?
Message 3 of 8
Guru
Message 4 of 8
schooner16
I will try setting up from scratch. Was just hoping there was a less extreme method to clearing.
At first it was the Apple TV that was listing multiple times.  Now its a harmony hub after a reboot.  I'm guessing it may be just the first device it recognizes.
Message 5 of 8
Guru
Sounds like something is messed up on the RBR. Hoping the reset will clear this up.
Message 6 of 8
schooner16
After factory resetting the router I can now see the devices on the mobile app and web page. Which is good news.  Performance and stability have been good to date but if there is one improvement I could mention it would be the mobile app and web page stability.  The apps/web page look and feel alright but since I have had the orbi the app it has shown many differenct behaviors.  First there was the no devices showing, but sometimes they would.  The renaming of devices debacle and now seeing all connected devices with the same name.  Hopefully the reset does it and and the behavior stays away.  The hardware(performance & stability) have been great but the software side could use some love and attention.
Message 7 of 8
Guru
Thank you for letting know.
I would be sure to make a back up configuration to file for safe keeping.
Yes, the Orbi app could problaby use some tuning. Something to post about over in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Please mark your thread and solved so others will know.
Enjoy. Smiley Wink
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2416 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
