- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netflix And Spectrum streaming on Roku
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netflix And Spectrum streaming on Roku
You don't have Armor enabled do you on the RBR? If you do, please disable it. Been others posting about Armor causing problems.
A factory reset maybe needed as well with the RBR and setup from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, this only clears any configurations that maybe causing problems. Try the reset and let us know.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you very much. I will try these and get back to you. Appreciate your time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
