Orbi WiFi 7 RBE973
Reply
Netgear Orbi RBR50 / Open reach modem UK
LloydG
Good morning.
Can anyone assist.
I'm currently using a BT Smart Hub 2 but it doesn't have modem mode. So I've purchased an openreach modem model ( B-Focus V-2fub/r Rev.B).
I've connected it to DSL , which it recognised and thought it would be a straight forward plug and play to the Orbi Internet / WAN port.
However the orbi is flashing purple and although showing as a network, is showing no IP address.
My technical knowledge is limited and it may be a simple fix. Any help would be appreciated.
I know that alternatively I could use the mesh in AP mode and turn off WiFi on my router and go that route, however I'd prefer this route first.
Message 1 of 6
Guru
Re: Netgear Orbi RBR50 / Open reach modem UK
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Message 2 of 6
LloydG
Many thanks.
I've gone for AP mode.
Unfortunately my BT smart Hub 2 doesn't have modem or bridge mode functionality so I've disabled WiFi.
I'm not a power user so strictly speaking don't need router mode. However is router mode quicker than AP?
Message 3 of 6
Guru
AP mode would have better performanced that router mode since the RBR doesn't have to process many features while in router mode.
Message 4 of 6
CrimpOn
Guru
@LloydG wrote:
Good morning.
Can anyone assist.
Could you clarify that the goal is to replace the BT Smart Hub2 with the Openreach modem (B-Focus V-2fub/r)?
I am not having a lot of luck find a user manual for that modem.
Message 5 of 6
LloydG
Yes ideally my initial goal was to replace the smart hub with the VDSL openreach modem.
I may still try a Netgear dm200 modem. But I've set up everything with the Orbi RBR50 in AP mode and deactivated WiFi on the smart hub. I've run speedtests on the Orbi router and each of the satellites via wired connections and I'm getting exactly the same speed as the Bt router so there's been no drop off in performance
Message 6 of 6
Discussion stats
  • 5 replies
  • 1080 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
