× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Orbi WiFi 7 RBE973
Reply
Netgear Orbi Satellite RBS50 bricked after update. Trying to TFTP to upload firmware. No Luck
Mills32
I have 2 Orbi RBS50 satellites that are bricked and I have been trying to use various ways of TFTP to upload the firmware to them and nothing is working. I have tried Tftpd64, the Windows command prompt, and nmrpflash with no success.
The satellite blinks a white light 20 times when turned on before it starts to pulsate a white light (this continues forever). I have tested when the orbi satellite pings for 192.168.1.1 and it is on the 3rd blinking white light so I know exactly when to try to push the firmware. I even saw a post where someone said you have to have an earlier firmware for it to work and I tried the firmware ending in 104. I tried using a network switch as well because while trying to push the firmware it doesn't show connected in windows via ethernet until after the 18th-ish blink of light. The network switch should theoretically keep the connection the whole time which it seems as though it did but it still didn't work. I have tried at different times as well. I actually tried at every interval of the white blinking light with all 3 methods listed above.
If anyone had any ways of getting it to work I would appreciate it. Mostly looking for people that have actually got a satellite working again. The routers are easier for some reason.
Message 1 of 4
Mills32
Re: Netgear Orbi Satellite RBS50 bricked after update. Trying to TFTP to upload firmware. No Luck
I have tried the 30-30-30 hard reset but it did not work.
My next option is to try the serial way which is the second forum post you tagged.
I will look through the other posts you tagged and see if anything helps.
Thanks for the input.
Message 3 of 4
Guru
Let us know how it goes.
Good Luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 185 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
