Orbi WiFi 7 RBE973
Reply
Netgear orbi router RBR 40 with RBW30 satelights I need a remote wired connection to my shop
DaveMortensen
Follower
I need to set up a wired connection to my shop that is 100 + feet away. Talking to my service provider they said the the easiest way was  to buy another orbi satelight and just plug it in to the cat 5 cable and an outlet and the satelight would mesh with the router. I would be all set. But the satelights that I have do not have a ethernet port to be able to plug into. What Orbi Satelight do I need to buy?
Message 1 of 2
Guru
Re: Netgear orbi router RBR 40 with RBW30 satelights I need a remote wired connection to my shop
Yes, you would need to use CAT6A out to the shop and you can use a RBS40v or EX7700 or 8000 in AP mode:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 224 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
