- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware 1.4.0.18 released
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bug Fixes:
- Fixes the add-on satellite sync issue.
- Supports the NETGEAR Orbi app.
http://kb.netgear.com/000036450/RBR50-RBS50-Firmware-Version-1-4-0-18
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware 1.4.0.18 released
I see it abilable after I login into router but thought it would auto update? I have not updated yet everyone is useing the router now and fear it would fail and have to do manually as I did after I purchased the router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Updated via the router webpage just fine, didn't have to master reset or reload any settings.
Couldn't find any info about the Orbi App, can't wait to take it for a spin when it is available.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: New Firmware 1.4.0.18 released
My printer (Dell 1660w) and all my LIFX light bulbs cannot connect to the wifi any more after I updated the firmware today.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, it wasn't the release that caused the problem, it was the "auto" setting for the wifi channel. I changed it to 11 and my LIFX bulbs and my printer can connect to the router again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did the update without any issues, took less then 5 min, no preformance issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got major speed decrease on iOS devices - dropped from about 200 Mbps to less as 20 or sometimes even 10 Mbps (measuered with Netflix / speedtest.net App).
Aynone else experienced this?
Any clue on how to correct this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello nlrela
I would try to log into the orbi and go to the wireless settings and try changing the wireless channel and see if that improves the speed. also are your other devices getting the high speeds and didnt experience the loss of speed?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi DarrenM
I have changed the channels unfortunately without any positive effect. And all devices are affected.
Only difference is, that I installed FW 1.4.0.18 .....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I am noticing that too, iPads, iPhone in my house are lot slower also android phones, tablets. Laptop is fine, hardwired speeds fine. yes did factory reset after updating Firmware and tried different channels only change being Firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you are willing to test you could try to load .16 back onto the router and check if the issue is fixed so I can report a issue with the latest firmware.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying hard to downgrade to .16, but only do see an hourglass for about an hour during uploading FW .... if I refresh or so then nothing has changed and I have to upload again
- Mark as New
- Bookmark
- Subscribe
- Permalink
After the 2nd reboot I succeeded with the downgrade ... will test speeds this weekend
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware 1.4.0.18 released: Speed Test after Upgrading
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here are my test results from before and after the update conntected to the router and to the satalite. Not that it helps with your problem since mine is working without issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
nlrela,
That is wired. I updated the Firmware to the latest, enabled QOS to eliminate Buffer Bloat and voila. Lower Buffer Bloat is what I was after. Wireless speeds across devices (Apple and Android, Tablet and phone) both are about the same speed. Wireless speeds were never that fast until I purchased the Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello nlrela
Thank you for testing this out I sent the issue over to engineering to try and replicate I may need to ask you some more info if you do not mind after I hear back from them.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was under the impression that QoS is really going to limit bandwidth unless you have some serious processing power to handle it. I know on my router enabling QoS disables HW offload and I end up going from 300Mbps to roughly 60 Mbps. I know I am looking at this router with a 9 core procesor just to handle QoS and not lose speed https://routerboard.com/CCR1009-7G-1C-1SplusPC. So maybe turn off QoS and see if your speed comes back?
- Mark as New
- Bookmark
- Subscribe
- Permalink
IOS devices about 50Mbps. (Iphone 6 and 7 and ipad air 2 and ipad pro) Router speedtest 363MBps. Macbook 563Mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
My router speedtest is 347 Mbps. My iphone 7 on speedtest.net is 178 Mbps. Seems not everyone is affected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue here. All my devices showed slower connection speeds on the new firmware. Just reverted back to .16 and speed is where it was before.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello everyone
I have been trying to track this issue with the latest firmware and IOS slow downs but make sure both the satellite and the main router are on the .18 FW some people have had the satellite on a older firmware and it was causing the issue.
DarrenM
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
