Orbi WiFi 7 RBE973
Reply
New framework and wifi calling
Celeri
Star
Hello,
Since new framework, and with Circle enabled, wifi calling stopped working.
When i disable Cicle, everithing works well.
Do you have this problem (i live in France, with SFR as provider)
Thxs !
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 14
Guru
Re: New framework and wifi calling
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275...
Has a factory reset been performed and set up from scratch after the FW update?
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highligh...
Message 2 of 14
Celeri
Star
Nothing worked ! Still no access to WiFi calls...
Message 3 of 14
schumaku
Guru
Message 4 of 14
Blanca_O
NETGEAR Moderator
Hi @Celeri
May I please know the following information:
- Carrier for Wi-Fi calling?
- Was it working before?
- Will it work if filtering level is set to NONE?
- Device/Phone affected?
We look forward to your response.
Blanca
Community Team
Message 5 of 14
Celeri
Star
Off course it was
YES
3 iPhone
Message 6 of 14
Blanca_O
NETGEAR Moderator
Hi @Celeri
Thank you for responding. I have sent you a message. Please check your inbox.
Blanca
Community Team
Message 7 of 14
ekhalil
Master
For Wifi Calling to work, your device needs to be able to reach to certain addresses (Fully Qualified Domain Names FQDNs). It seems that Circle -for some reason- is blocking those FQDNs. Please check with your Wi-Fi Calling provider which FQDNs are needed so that you can set Circle to allow, examples should be like (I'm just putting SFR as an example, but the addresses can be something else, please check this with your operator):
  • epdg.epc.sfr.net (to reach to the ePDG in the network)
  • sentitlement2.mobile.sfr.net (for the Entitlement server, if any, used for multiple devices)
Message 8 of 14
Guru
Seems like something with Circle in new FW is causing problems...
@Blanca_O
@Celeri wrote:
Hello,
Thxs !
Message 9 of 14
Celeri
Star
Any news about this problem ? For me it still does not work.
Message 10 of 14
ekhalil
Master
@Celeri Can you please test the following to confirm the theory that Circle is blocking the needed FQDNs from the phone to your operator:
Can you please go to the Circle app, choose the user for which the device who have problems with wifi calling belongs to, select "Filter", then "Custom Filter", add sfr.fr and keep it as "Allowed".
Message 11 of 14
Guru
I would contact NG support about this if you can't seem to get it working correctly.
Message 12 of 14
Celeri
Star
I
tried but it does not change anything
Message 13 of 14
ekhalil
Master
@Celeri wrote:
I
The domain sfr.fr was just a guess :), can you check with sfr what the real FQDN is? or please try other possible domains like sfr.com, sfr.net,.....
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 3193 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
