- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI AC2200 = satellite keeps defaulting to 2.4
- Mark as New
- Bookmark
- Subscribe
- Permalink
ORBI AC2200 = one satellite gets 5.0, but the other keeps defaulting to 2.4.
Any way to fix this, or do I need to return it?
My son says there is a Nighthawk that works better. Please advise.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI AC2200 = satellite keeps defaulting to 2.4
What do you mean by defaulting to 2.4?
What devices are you connecting to the Orbi system?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The modem is an Arris DG2480.
We have 400 mbps internet service.
We got the NETGEAR - Orbi AC2200 Tri-Band Mesh Wi-Fi System (3-pack). One satellite gets a 5.0 channel, but the other one of the satellites keeps defaulting to the 2.4 channel. Any way to fix this? One gets approx 280mbps, the other around 75mbps.
Each satellite is about 40-45 feet from the main Orbi. Our home is a two-story, 3600 sq ft.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you swap the two satellites? (exchange locations) Radio connects in a straight line. Perhaps there is too much immaterial n the direct path for the 5G signal to penetrate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What Firmware is currently loaded on the RBR and RBS? Ensure all units are on the same version of FW.
Has a factory reset been performed on the one RBS that seems be not working?
How are you determining that the one RBS is only defaulting to 2.4Ghz?
What devices are you connecting to the RBS?
Using any wifi apps?
FYI, your ISP modem has a built in router and wifi already. Have you diabled its' wifi here as well? Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thx, I'll have my son review your comments!
- Mark as New
- Bookmark
- Subscribe
- Permalink
My ISP says they would have to come out to put the modem/router into BridgeMode.
They suggested I just buy a new modem, and turn in the old one.
Our current modem/router is an Arris DG2480.
Would do you recommend? 16x4 or 32x8 ?
ISP says to get minimum Docsis 3.0. Do you agree? Or, should it be 3.1?
How about this one?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:
I would recommend the CM1000:
https://www.netgear.com/support/product/CM1000.aspx
Whatever you do, if you buy Netgear go for "CMXXXX" models. That is the modem only option.
Some people have gone for a CXXXX model which is a modem/router and all of the hassle that that entails.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
