Orbi WiFi 7 RBE973
Reply
ORBI CBR40 and RBS20 Satellite
MWatson1027
Follower
Hello! I bought this mesh system in 2020 for my house with guest house (approximately 4000sq feet total) which are side by side. Never had any issue with it until the last week or so my satellite won't stay connected to the router. It isn't the magenta color I saw in other threads its usually white when it disconnects. Resetting it seems to help for a bit but no more than a few hours. The router and satellite are in separate rooms approximately 25 feet apart and approximately 35 feet from the devices needing to utilize the satellite services. Any ideas on how to fix it?
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
Message 1 of 2
Guru
Re: ORBI CBR40 and RBS20 Satellite
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBE971 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 519 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
